Perform this task to run a VM command from EDM. To include spaces in the syntax,
include the text string in quotation marks (").
In the navigation pane, expand .
Select the Virtual Service.
Select the Globals
tab.
In ScalarsName, type
a virtual service name.
In ExecuteCommand,
type the ls
command for the VM configs directory. For example, "ls
/home/rwa/configs".
In FigwCli, type a
command to send it to the Fabric IPsec Gateway. For more information about
Fabric IPsec Gateway commands, see VOSS Command References.
Select Apply.
